Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_qnaplog
Qnaplog plugin
This plugin reads the Qnap logs (connections or events).
The plugin dont disturb the standby of the Qnap. Only when the log files are changed, the plugin reads the sqlite database.
Settings
Plugin QnapLog {
    databaseConn  '/etc/logs/conn.log'	# if none, /etc/logs/conn.log is assumed
    databaseEvent '/etc/logs/event.log'	# if none, /etc/logs/event.log is assumed
databaseConnpath to the sqlite database with the connection log
databaseEventpath to the sqlite database with the event log
Functions
qnaplog::conn(f)call qnaplog::conn() and return field <fconn>
qnaplog::event(f)call qnaplog::event() and return field <fevent>
qnaplog::status(db)returns 'Ok' if the database can be opened, otherwise an empty string. db is 'conn' or 'event'.
The field 'fconn' can have the following values:
FieldDescription
ressourcedescription of ressource (filename etc.
ipip address of the user
typetype like Information, Warning, Error
actionaction like Read, Write, Add, Delete
servconnection like HTTP, Samba, SSH
username of the user
computername of the connected computer
timeaccess time
dateaccess date
The field 'fevent' can have the following values:
FieldDescription
descriptiondescription of the event
timeaccess time
dateaccess date
Examples
Widget QnaplogActionFile {
    class 'Text'
    expression qnaplog::conn('action').': '.qnaplog::conn('ressource')
    width 20
    foreground '0000bbff'
    align 'M'
    speed 200
    update 1000
Example result: 'Read: home/data/file.txt'
Widget QnaplogDate {
    class 'Text'
    expression qnaplog::conn('date')
    prefix 'Date: '
    width 20
    align 'L'
    update 1000
Example result: 'Date: 2009-04-25'
Widget QnapEventDesc {
    class 'Text'
    expression qnaplog::event('description')
    prefix 'Event: '
    width 20
    align 'M'
    speed 200
    update 1000
Example result: 'Event: HDD SMART: HDD 1 Quick Test started.'
lcd4linux/plugin_qnaplog.txt · Zuletzt geändert: von 127.0.0.1
