Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_raspi
Raspi Plugin
This plugin provides data about the internal sensors of the raspberry pi.
NOTE: This plugin is disabled by default, and must be explicitly enabled in /etc/lcd4linux.conf:
Plugin raspi {
    enabled 1
Functions
raspi::cpufreq() get the actual cpu frequency in MHz as float value
raspi::cputemp() get the actual cpu temperature in degree Celsius as float value
If one of the sensors is not readable it is disabled. The value for cpu frequence normally can only be read by root.
lcd4linux/plugin_raspi.txt · Zuletzt geändert: von 127.0.0.1
