lcd4linux:plugin_test
Test plugin
This plugin provides two functions primary for testing purposes.
Functions:
| test:bar(index, max, start, delta) | returns a value between 0 and max |
| test::onoff(index) | returns 1 and -1 in turn every time called |
The test::bar function is used for testing bars. It keeps values for up to 10 bars (specified with the <index> parameter) which are incremented and decremented between 0 and <max> by amount <delta> every time they are read. Starting value is <start>.
The test::onoff function is used for testing the visibility of icons. It provides up to 10 values (specified with the <index> parameter) which switch between -1 and 1 every time it is called.
lcd4linux/plugin_test.txt · Zuletzt geändert: von 127.0.0.1
