lcd4linux:plugin_w1retap
Inhaltsverzeichnis
w1retap plugin
This plugin returns the value that belongs to a key from a file with lines in the form KEY=VALUE. It was written by Jonathan Hudson for the w1retap weather station logging software (1-Wire sensors), but it can be used with every file in this format.
Functions
| w1retap::readkey(file, key) | returns the value of key from file |
- The file is read at every call, the first line that starts with key= is used.
- The value ends at the first blank or at the end of the line, so a unit after the value (OTMP0=12.34 C) is cut off.
- If the value is a number, it is formatted with one decimal place; values greater than 500 (e.g. the air pressure) are formatted without decimal places.
- If the key is not found or the file cannot be opened, an empty string is returned.
Example
A file /tmp/.w1retap.dat with this content
OTMP0=12.34 C OPRS=1013.25 hPa
and this configuration
Variables {
tick 120000
file '/tmp/.w1retap.dat'
Widget Temp {
class 'Text'
expression w1retap::readkey(file, 'OTMP0')
prefix 'Extr '
width 10
align 'L'
update tick
Widget Press {
class 'Text'
expression w1retap::readkey(file, 'OPRS')
prefix 'Pres '
width 10
align 'L'
update tick
will display 'Extr 12.3' and 'Pres 1013'.
For other files in the form key=value see also file::readconf() of the file plugin.
Requirements
No external libraries. The plugin is selected at build time with –with-plugins=w1retap (it is part of 'all').
lcd4linux/plugin_w1retap.txt · Zuletzt geändert: von 127.0.0.1
