Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:widget_ttf
Truetype Widget
This widget is available on graphic displays only!
The Truetype widget renders the result of an expression with a TrueType font. In contrast to the text widget, which uses the built-in 6×8 bitmap font, it gives you smooth, anti-aliased text in any size and colour. Internally the text is rendered into an image, so the widget behaves like an image widget: it is placed with pixel resolution and may be put on its own layer.
The definition of a Truetype widget looks like this:
Widget myText {
    class       'Truetype'
    expression  <expr>
    font        <string>
    size        <number>
    fcolor      <color>
    width       <number>
    height      <number>
    align       <char>
    mheight     <char>
    center      <0|1>
    debugborder <color>
    update      <number>
    reload      <0|1>
    visible     <0|1>
    inverted    <0|1>
All entries except class are expressions and are evaluated at every update.
Parameters
expressionthis expression will be evaluated and its result will be displayed
fontpath to the TrueType font file (*.ttf). Required.
sizefont size in points. Default is 0, which means automatic (see below).
fcolorfont color as RRGGBB or RRGGBBAA, default is red 'ff0000'. Note the alpha channel, see below.
width, heightsize of the widget in pixels. Default is 0, which means: as big as the rendered text.
alignhorizontal alignment of the text inside width: 'L' (left), 'C' (center, the default) or 'R' (right). Needs width and height.
mheighthow the height of a text line is determined: 'F' (full, the default), 'N' (numbers) or 'O' (old), see below
centerset to 1 to center the widget horizontally on the display; the X position from the layout is ignored then
debugbordercolor (RRGGBB or RRGGBBAA) of a frame that is drawn around the area given by width and height. Useful while designing a layout. Default is '000000', which means no frame.
updateupdate interval (msec), default is 100. Use 0 (zero) for static text.
reloadexpression controlling whether the text is rendered again at an update. Default is 0, see below.
visibleexpression controlling the visibility (for blinking effects)
invertedexpression controlling the inversion
reload
The text is rendered when the widget is created. At every following update it is rendered again only if reload evaluates to a value other than zero. With the default (0) the widget keeps showing the first result of expression, only visible and inverted take effect.
So for everything that changes (a clock, a title, a temperature), set
    reload 1
Size of the text
There are three ways to determine the size:
size > 0, no width/heightThe text is rendered in the given size, the widget is as big as the text.
size > 0, width and height givenThe text is rendered in the given size into an area of width x height pixels and aligned as specified with align.
size 0, width and height givenAutosize: the biggest font size is used with which the text fits into width and a text line fits into height. Long texts get smaller, short texts get bigger.
Both width and height must be given for alignment and autosize; with only one of them the widget behaves as if none was given. With size 0 always specify width and height.
The mheight entry selects the characters that are used to measure the height of a line. This matters for autosize and for the vertical position of the text:
'F'full: the height is measured with a set of characters with ascenders, descenders and accents. The baseline stays at the same place for every text. This is the default.
'N'numbers: only an upper case umlaut and a lower case letter with descender are used. Oversized characters like brackets are ignored, so digits and normal text can be a bit bigger.
'O'old behaviour: the height is measured with the displayed text itself. The text jumps up and down if it changes between e.g. 'aaa' and 'Ago'.
Colors
fcolor and debugborder are RGB values with an optional alpha channel. Attention: the alpha channel of this widget works the other way round than in the other color entries of LCD4Linux: '00' is opaque and 'ff' is (nearly) transparent.
'ffffff'white, opaque
'ffffff00'white, opaque
'ffffff80'white, half transparent
The background of the widget is always transparent, so the text can be placed on top of an image on another layer.
Layout
Like the image widget, the Truetype widget is not placed on a row/column basis, but with true pixel resolution:
Layout Default {
    Layer 1 {
        X10.Y1 'Clock'
    Layer 2 {
        X1.Y1 'Background'
Note that the number after X is the vertical position (the row) and the number after Y is the horizontal position (the column), counted in pixels and starting with 1.
Example
A clock that is scaled into an area of 300×80 pixels and centered on the display:
Widget Clock {
    class      'Truetype'
    expression strftime('%H:%M', time())
    font       '/usr/share/fonts/DejaVuSans-Bold.ttf'
    size       0
    width      300
    height     80
    align      'C'
    mheight    'N'
    fcolor     'ffffff'
    center     1
    reload     1
    update     1000
A title in a fixed size, as wide as the text:
Widget Title {
    class      'Truetype'
    expression file::readline('/tmp/lcd/event', 1)
    font       '/usr/share/fonts/DejaVuSans.ttf'
    size       24
    fcolor     'ffcc00'
    reload     1
    update     2000
Requirements
The Truetype widget is built together with the image widget, if the GD library (libgd 2) is found at build time. libgd must be compiled with FreeType support.
lcd4linux/widget_ttf.txt · Zuletzt geändert: von 127.0.0.1
