Pluto TV
Has thanked: 171 times
Re: Pluto TV
jokel hat geschrieben: Do 4. Nov 2021, 20:40
nochmal die aufnahme angesehen, aufnahme ist ohne werbung?
Die Werbeblöcke sind mit Sicherheit in einem anderen Format, daher auch dann wegen dem Wechsel nicht in der Aufnahme. Müsste man mal genauer analysieren.
Bringen wirds aber unterm Strich nichts.
Has thanked: 66 times
Been thanked: 208 times
Re: Pluto TV
kein epg
[neutrino] got 928 TV and 135 RADIO channels
[neutrino] all channels took: 5 msec
[neutrino] created Kabel Deutschland (626/Q256) (3845) bouquet with 336 TV and 135 RADIO channels
[neutrino] sat took: 15 msec
[neutrino] got 592 WebTV channels
[neutrino] got 12 removed TV channels
[neutrino] sats took: 20 msec
[neutrino] got 72 TV and 18 RADIO bouquets
[neutrino] took: 21 msec
[neutrino.cpp:SetChannelMode:2639] newmode 0 sort old -1 new 3
CChannelList::adjustToChannelID me 0x1653e70 [Alle Kanäle] list size 928 channel_id 5555043700012b66
[neutrino] curl error: The requested URL returned error: 404 (https://static.filmon.com/assets/channels/6176/logo.png?v2)
2021-11-04 22:04:45.253 [sectionsd] Reading data finished after 555 ms (2 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/PlutoTV/de.xml
2021-11-04 22:04:45.317 [sectionsd] Reading data finished after 558 ms (0 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/at.xml
2021-11-04 22:04:45.601 [sectionsd] Reading data finished after 812 ms (0 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/ch.xml
2021-11-04 22:04:45.755 [sectionsd] Reading data finished after 937 ms (0 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/SamsungTVPlus/de.xml
2021-11-04 22:04:45.820 [sectionsd] Reading data finished after 1093 ms (0 events) from https://raw.githubusercontent.com/matthuisman/i.mjh.nz/master/PlutoTV/us.xml
[neutrino] curl error: The requested URL returned error: 404 (https://static.filmon.com/assets/channels/6197/logo.png?v2)
[neutrino] curl error: The requested URL returned error: 404 (https://static.filmon.com/assets/channels/6194/logo.png?v2)
[neutrino] curl error: The requested URL returned error: 404 (https://static.filmon.com/assets/channels/6191/logo.png?v2)
ShowText '22:04'
ShowText '22:04'
2021-11-04 22:04:56.750 [sectionsd] Removed 171 old events (28506 left), zap detected 0.
[HAL: 005ccd58:init  ] [CEC] received message TV to Tuner 1 (0x00>>0x03) 'give device power status' ([0x8F])
[HAL: 005ccd58:init  ] [CEC] send message Tuner 1 to TV (0x03>>0x00) 'report power status' ([0x90][0x00])
ShowText '22:05'
Has thanked: 20 times
Been thanked: 40 times
Re: Pluto TV
aktualisier mal, geht wieder.
edit: wurde um 22:03 an der Quelle aktualisiert. Kann man ja auch selber mal nachschauen, oder? ;)
Re: Pluto TV
ich schaue, wie scheinbar einige hier :vulcan: , auf Pluto TV Star Trek die Serie "Star Trek: Discovery", sonst hab ich nur mal bei denen reingeschaut, habe also wirklich nur Erfahrungen seit 4 Tagen mit Pluto.
Es ist so, dass der Stream ansich recht stabil läuft, halt nur die Werbeunterbrechungen bzw der Sendungswechsel Probleme bereitet.
Interessant ist aber, dass nur während der Werbepausen sowas im Log der Tank auftaucht:
CSAPI (FILEPLAYER): VIDEO event 39: STC valid, err 4999988
CSAPI (FILEPLAYER): VIDEO event 38: STC valid, err 44
CSAPI (FILEPLAYER): Try to sync
CSAPI (FILEPLAYER): VIDEO event 38: STC valid, err 0
Die mit dem "err 0" am Ende kommt so ca alle 10 oder 15 Sekunden. Wenn dann die Sendung wieder einsetzt, ist wieder Ruhe.
Aber das Problem mit dem Hänger und Asynchro beim Sendungswechsel (also nächste Folge), scheint wohl auch für andere Software ein Problem zu sein, da sind wir wohl nicht alleine.
Re: Pluto TV
hat schon jemand einen trick gefunden das man pluto-tv über den timer aufnehmen kann?
Re: Pluto TV
Das geht ganz ohne jeden Trick, aber ob mit oder ohne Timer, die Aufnahmen sind immer kaputt und wenn Die Aufnahme wärend der Werbeunterbrechung beginnt kann es sein das nur diese aufgenommen wird.
Re: Pluto TV
Die Nachlaufzeit des Timers soweit erhöhen, dass die letzte Werbepause vorbei ist.
10 Minuten ware im ersten Versuch zu wenig. Aufzeichnung war über die Werbepause gekommen, aber noch vor dem Abspann zu Ende. Ich vermute, dass hängt mit der unkalkulierbaren internen Zeitberechnung während der unsichtbaren "Werbeblocks" :D zusammen.
Die Vorlaufzeit habe ich auf 2 Minuten gesetzt. Damit startet die Aufnahme im Abspann der vorherigen Folge.
Da die "Lauf"-Zeiten irgendwie astronomisch erscheinen, habe ich - wie zuvor schon beschrieben - die Aufnahmen sequenziert, damit keine Überlappungen auftreten.
Da idR 4-5 Folgen nacheinander "gesendet" werden, habe ich 1 > 3 > (5) > 2 > 4 programmiert.
Und ich vermeide es auf jeden Fall, neben der Aufnahme parallel PlutoTV live zu schauen.
Dabei ist es egal, ob die Box im Standby ist oder ich während der Aufnahmen über vorhandene Tuner Live-TV schaue.
Könnte höchstens mal versuchen, die Duo4K parallel mit Pluto laufen zu lassen.
Mal sehen, ob meine bescheidenen 50 MBits dafür ausreichen...
Re: Pluto TV
der stream also pluto wird super mit werbung abgespielt,da muss es doch möglich sein das aufnehmen zu können.
in der sofort aufnahme geht das.allerdings nur wenn ich den stream schaue,ansonsten ende ich wie gorcon beschrieben hat
mit einer aufnahme die unbrauchbar ist. liegt das am plugin?
Re: Pluto TV
Ich vermute mal, dass die Werbung "senderübergreifend" eingespielt wird.
Müsste ich das organisieren, würde ich eine separate - immer gleichbleibende - URL während der Werbeeinblendung über die jeweilige Stream-URL legen.
Ich glaube nicht, dass Neutrino beim Streaming auf dynamischen Wechsel der URL "vorbereitet" ist.
(bei DVB scheint es ja zu funktionieren mit der dynamischen Umschaltung (ARD Test-R))
Das Verhalten der Aufzeichnung entspricht dabei auch dem Verhalten normaler Aufnahmen, wenn ich mitten drin meine Karte ziehe => Die Aufzeichnung läuft weiter, allerdings nur "Schwarzbild". Bei der Wiedergabe wird dieser Bereich dann im "Eiltempo" überlesen. Bis Karte wieder eingesteckt wird oder das Aufnahmeende tatsächlich erreicht wird.
Ich habe die Nachlaufzeit nochmal auf 12 Minuten verlängert. Jetzt sehe ich den Schluss inkl. Beginn des Abspanns.
Jetzt hoffe ich, dass die Staffel 1 - unter den gleichen Voraussetzungen - später nochmal wiederholt wird ...
Re: Pluto TV
bin ein bisschen durcheinander erst staffel 1 jetzt schon staffel 3 deswegen wollte ich das aufnehmen,geht aber nicht
weil die aufnahmen kaputt sind.macht also keinen sinn das aufzunehmen.ich habe prime aber bei amazon wird star terk
enterprise nicht gelistet nur discovery gegen kohle.
Re: Pluto TV
ich habe vornhin mal kurz vor Sendungsende die Playlisten in meinem Browser "abgegriffen" (s. Anhang). Also es lief noch die alte Folge, dann kam Werbung, dann der Abspann, danach die kurze Unterbrechung vor dem Beginn der nächsten Folge.
Man kann schön sehen, dass es für Werbung und Pause eine andere Streamadresse gibt (sieht man in playlist(3) ). Scheinbar sogar für jeden einzelnen Werbeclip eine andere Adresse.
Wie üblich war die neue Folge asynchron (in playlist(13) sieht man den Übergang).
Bis einschl playlist(18) habe ich gewartet, ob sich der Stream "fängt" (tat er nicht), dann doch gerezapt (ab playlist(19)_rezap, Ton wieder synchron).
In pluto_test2 ist das parallel mitlaufende Log der Tank zu sehen.
Keine Ahnung, ob man damit was anfangen kann. Eine Art "Werbeblocker" wäre damit aber evtl durchaus möglich. :D
Nur warum die neue Folge asynchron ist, ist wohl die eine Million Euro Frage. Liegt das vllt an der doppelten "#EXT-X-DISCONTINUITY" hintereinander in playlist(13), oder dass die "#EXT-X-DISCONTINUITY-SEQUENCE:" von 11 auf dann 13 springt???
plutotest.zip
(14.87 KiB) 260-mal heruntergeladen
Has thanked: 44 times
Been thanked: 23 times
Re: Pluto TV
Don de Deckelwech hat geschrieben: Fr 5. Nov 2021, 17:56 Nur warum die neue Folge asynchron ist, ist wohl die eine Million Euro Frage.
// mutmaßung an
kann es evtl. an der voreingestellten videoauflösung liegen?
die pluto-sender kommen nativ idR mit 30fps an.
ich stelle diese sender meist über die v-format taste auf 720p 60hz um.
damit habe ich weniger geruckel im bild und bisher auch keinen bild/tonversatz.
wenn dann die werbung dazwischen in 720p 50hz ankommt....entsteht beim normalen programm dann evtl. asynchronität?
// mutmaßung aus
Re: Pluto TV
Meine HD51 steht auf VideoMode 2160p 50Hz mit Vollbild auf 16:9
WebTV ist mit Auflösung 1920x1080 eingerichtet.
Asynchroner Ton ist mir bisher nicht aufgefallen.
Ich hatte anfangs auch WebTV mal auf 3840x2160 eingestellt,
kam aber eh nur mit geringerer Auflösung hier an. Auch ohne Tonversatz.
Re: Pluto TV
Manchmal habe ich das Gefühl, hier drehen sich alle im Kreis. Willst du jetzt wirklich behaupten, du hast keinerlei Probleme, wenn bei Pluto Star Trek eine Sendung aufhört und die nächste dann anfängt??? Oben hast du doch iirc noch was anderes behauptet, oder warum verbiegst du die Aufnahmenachlaufzeiten etc?
Re: Pluto TV
Nachlaufzeien:
Weil mir sonst hintenheraus Teile des Contents fehlen!
etc.:
Weil mir paralleles Live-Sehen und Aufnehmen anfangs direkt einmal zu mülligen Aufnahmen führte.
Jemand hat das oben schön beschrieben: Es war nur der Teil nach der letzten Werbepause abspielbar.
Da habe ich auf fehlerhaften Ton beim Abspann erst garnicht geachtet.
Der Content selbst ist seitdem hier immer lippensynchron. Vielleicht weil ich erst garkeine überlappenden Aufnahmen mache und/oder keine konkurrierenden Backends audf den gleichen Stream loslasse.
Und ich beschreibe hier eigentlich nur den gewünschten Trick. Wie gewohnt nach Art des Hauses.
Fehler suchen und Fixen muss das halt ein Anderer...
Re: Pluto TV
ok soweit.
Ich hatte bisher nur auf Tank getestet. Gerade die HD51 mal wieder angeworfen, aktuelles Nightly geflasht, und gerade noch den Schluss von ST: Enterprise mitbekommen.
Der Async ist deutlich kleiner, fast überhaupt nicht zu sehen, so im Millisekundenbereich (statt 5 - 10 Sekunden auf der Tank), aber er war da. Nach Rezap sieht das deutlich besser aus.
Muss man mal weiter beobachten.
PS: im Telnet-setconsole-Log der HD51 sind andauernde Debug-Infos zu sehen, sowas hier (kommt so alle 4-5 Sekunden):
erverSideAds=true' for reading
[hls @ 0xab27c680] Skip ('#EXT-X-VERSION:3')
[hls @ 0xab27c680] Skip ('#EXT-X-DISCONTINUITY-SEQUENCE:0')
[hls @ 0xab27c680] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-11-05T19:36:19.897Z')
[hls @ 0xab27c680] Skip ('#PLUTO-SESSION-ID:22b27aa50-90b-1026-216d76e80efe')
[hls @ 0xab27c680] Skip ('#PLUTO-VERSION:2.60.0-production-stitcher-green')
[hls @ 0xab27c680] Opening 'crypto+http://siloh-aka.plutotv.net/c6009f_plu ... i_Prime_S3
E018/720p/20211026_070407/hls/0-1303720/hls_2400-00128.ts' for reading
[http @ 0xa5b761b0] Opening 'http://service-stitcher.clusters.pluto. ... 8?advertis
ingId=&appName=web&appVersion=unknown&appStoreUrl=&architecture=&buildVersion=&clientTime=0&deviceDNT=0&deviceId=216a180d9-14a2-2299-48511d24eba9
&deviceMake=Chrome&deviceModel=web&deviceType=web&deviceVersion=unknown&includeExtendedEvents=false&sid=22b27aa50-90b-1026-216d76e80efe&userId=&s
[hls @ 0xab27c680] Skip ('#EXT-X-PROGRAM-DATE-TIME:2021-11-05T19:36:24.897Z')
E018/720p/20211026_070407/hls/0-1303720/hls_2400-00129.ts' for reading
edit 23:18h : also auf der HD51 läuft das eigentlich ganz gut, kein Vergleich zur Tank
Been thanked: 70 times
Re: Pluto TV
Janus hat geschrieben: Fr 5. Nov 2021, 19:32Asynchroner Ton ist mir bisher nicht aufgefallen.
Habe ich hier auf HD51, VU+ (Ultimo4K/Duo4K und SE) und selbst auf der alten UFS910 ebenfalls nicht - wobei die alte UFS910 aufgrund des geringen RAM arg zu pumpen hat. Ist der Swap zu langsam, zu klein oder zu groß, kommt sie ins stocken. Da kommt die AV7500 besser mit klar. :)
Don de Deckelwech hat geschrieben: Fr 5. Nov 2021, 20:37Gerade die HD51 mal wieder angeworfen, aktuelles Nightly geflasht, und gerade noch den Schluss von ST: Enterprise mitbekommen.
Der Async ist deutlich kleiner, fast überhaupt nicht zu sehen, so im Millisekundenbereich...
Ähm, sowas bei synchronisierten Filmen/Serien zu sagen ist mutig, denn das kann man nur sicher bei deutschen Filmen/Serien sagen. Schließlich klappts bei einer Synchronisation nicht 100% Lippensynchron.
Re: Pluto TV
Selbst wenn es die gleiche ist wie bei RakutenTV, dann wird der Stream dennoch zusammengebastelt.
Ist das gleiche wie mit den dritten Programmen wenn die zur Regionalprogramme umschalten. Das kann man auch nicht aufnehmen.
BPanther hat geschrieben: Sa 6. Nov 2021, 01:38
Man kann sowas aber u.U. an Geräuschen erkennen. Allerdings greift ja die Verzahnung der Syncronfunktion die solchen Versatz nicht zulässt. Deutlich größere Versätze sind aber eben durchaus möglich.
Re: Pluto TV
Ist hier Gestern komplett in die Hose gagangen.
Sowohl drei Aufnahmen ( 1 > 3 > 2 ) mit der HD51 (mit gleichzeitigen LiveTV-Betrieb Sat und Kabel)
als auch die Folge 4 der ersten Session mit der Duo4k (im Standby auf Astra1::ARD)
- Habe wohl die Vor- und Nachlaufzeiten zu stark vergrößert.
Damit scheine ich zu Anfang und am Ende wieder in die Werbezeit zu geraten.
- Und bei beiden Boxen in WebTV die Auflösung wieder auf 3840x2160 gestellt.
Da lt. Infoviewer die Auflösung nur mit 720 Zeilen angegeben wird, könnte darüber auch ein Problem mit dem Dateigrößen-Handling der "Schwarzbild"-Phasen in den Werbepausen entstanden sein. Könnte auch die seltsamen Zeitangaben erklären.
Die Fehler waren auf beiden Boxen identisch.
Der nächste Versuch wird Heute mit
* Vorlauf 1 min
* Nachlauf 10 min
* Auflösung 1280x720
ausgeführt. Mal sehen, was dann dabei rauskommt.
Und ich hoffe, dass das StarTrek Discovery - Material nach der dritten Staffel komplett nochmal wiederholt wird. Bisher habe ich nur von Vorgestern 3 Folgen (von 21), die ziemlich vollständig aussehen.
Vielleicht ist dann auch der eigentliche Fehler gefunden und gefixt.
Werbeblöcke kann man bei der Wiedergabe ja überspringen...
Re: Pluto TV
BPanther hat geschrieben: Sa 6. Nov 2021, 01:38Ähm, sowas bei synchronisierten Filmen/Serien zu sagen ist mutig, denn das kann man nur sicher bei deutschen Filmen/Serien sagen. Schließlich klappts bei einer Synchronisation nicht 100% Lippensynchron.
Ja, da hast du natürlich recht. Das war auch eher mein erster Eindruck, und sollte verdeutlichen, dass die HD51 wohl keine Probleme hat. Ich habe mir gestern die 4 Folgen ST:Discovery komplett auf der HD51 angeschaut, das lief ziemlich gut.
