EPG und Logos für WEBTV Sender
Has thanked: 71 times
Been thanked: 212 times
Re: EPG und Logos für WEBTV Sender
das glaube ich auch
Tue Apr 6 07:45:30 UTC 2021
dinobot start!!!
Load hi_media.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:34:03])
Load hi_mmz.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:34:05])
random: nonblocking pool is initialized
virtual device initialization.
Load hi_common.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:34:07])
Load hi_pq.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:29])
Load hi_cipher.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:35:31])
Load hi_hdmi.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Aug 26 2019, 15:05:37])
Load hi_vou.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:37:03])
Load hi_gpio.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:35:49])
Load hi_gpioi2c.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:08])
Load hi_i2c.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:09])
Load hi_tde.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:40])
Load hi_otp.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:20])
[06:17:07:093 ERROR-HI_HDMI]:ParseTimingDetailed2Standaed[882]:PixelClk: 25175 >74250 Interlace:1 ,Pixel:12ddb0
Load hi_demux.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:35:33])
Load hi_adec.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:34:57])
Load hi_vfmw.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:51])
Load hi_vpss.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:37:19])
---HDMI kernel event(no UserCallBack): HOTPLUG. ---
Load hi_vdec.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:46])
Load hi_adsp.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:34:58])
Load hi_aiao.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:35:05])
Load hi_tuner.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jul 15 2019, 21:53:56])
Load hi_fb.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:03])
Load hi_ir.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:10])
Load hi_jpegdec.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:14])
Load hi_png.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:25])
Load hi_advca.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:35:00])
Load hi_keyled.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Aug 28 2020, 14:14:44])
Smartcard driver (sci)
Version 4.00 (c) 2016-2017 Honza Petrous
scifi: register /dev/sci0
Load hi_vi.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:53])
Load hi_pmoc.ko success. (SDK_VERSION: [HiSTBLinuxV100R005C00SPC060_20180714] Build Time: [Jun 21 2019, 15:36:22])
read des data length = 1024
des_decrypt is ok
videomode-->720p
enSpdifMode 0 enHdmiMode 0
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.AC33.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DTSS.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.TRUEHD.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.AMRWB.codec.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.Mp3.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.MP2.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.AAC.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DOLBYTRUEHD.decode.so failed
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DRA.decode.so2u32KeyId 1 1
success
HI_UNF_AVPLAvideomode_preferred setting
Y_RegisterAcodecLib libHA.AUDIO.TRUEHDPASSTHROUGH.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.AMRNB.codec.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.WMA.decode.so failed
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.COOK.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.G711.codec.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DTSHD.decode.so failed
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DTSM6.decode.so failed
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.DTSPASSTHROUGH.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.AC3PASSTHROUGH.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.PCM.decode.so success
HI_UNF_AVPLAY_RegisterAcodecLib libHA.AUDIO.BLURAYLPCM.decode.so succeshisi com_size 100
das war auch interessant,
https://github.com/dizzdizzy/HiOSCAM
https://www.satking.de/receiver--sat-te ... at-Receive
dni
Beitrag von dni »
So ich denke ich habe das Problem behoben. Ich muss es aber noch final testen heute Abend daheim. Ist remote evtl. nicht 100% gut :-)
Workaround:
Datei ni-libstb-hal/libarmbox/audio.cpp Zeile 207 - 211:
        if (fd > 0)
                if (ioctl(fd, AUDIO_SET_MIXER, &mixer) < 0)
                        perror("AUDIO_SET_MIXER");
Hier war (fd > 0) false... ich habe folgende Abfrage quick und dirty eingebaut damit der ioctl AUDIO_SET_MIXER ausgeführt wird:
        if (fd < 1)
                openDevice();
        if (fd > 0)
Danke für eure Hilfe ;-)
Ich meld mich nochmal wenn ich es live probiert habe.
interessant ist auch zeile 225
#if BOXMODEL_HISILICON
	ioctl(fd, AUDIO_CONTINUE);
#endif
dni
Beitrag von dni »
jokel hat geschrieben: Do 21. Jul 2022, 14:06 interessant ist auch zeile 225
#endif
ja genau dadurch bin ich drauf gestoßen ;-)
dni
Beitrag von dni »
dni hat geschrieben: Do 21. Jul 2022, 13:35 Danke für eure Hilfe ;-)
Ja, funktioniert einwandfrei 😁
Has thanked: 56 times
Been thanked: 97 times
Danke dir. Ich habe das eingecheckt. https://github.com/neutrino-images/ni-l ... 9874fc26d9
dni
Beitrag von dni »
vanhofen hat geschrieben: Do 21. Jul 2022, 21:08 Danke dir. Ich habe das eingecheckt. https://github.com/neutrino-images/ni-l ... 9874fc26d9
Ah cool, dann brauch ich meinen Patch nicht mehr.
Freut mich, dass ich so ein cooles Projekt mal unterstützen konnte. 👍
Wobei ich mich ja immer noch frage, warum das nur bei mir so ist, bzw. nur bei Hisilicon Boxen...
dni hat geschrieben: Do 21. Jul 2022, 14:18
#endif
damit wollte ich nur sagen das jemand versucht hat das problem zu lösen.
deine quick und dirty methode sieht erstmal in meiner audio.cpp so aus,
	if (fd < 1)
		openDevice();
#endif
da das hisilicon spezifisch ist.
hast du mal im log geschaut ob da eventuell sowas auftaucht?
already open
oder
open failed
dni
Beitrag von dni »
Die CONTINUE Dinger kommen hierher
https://github.com/neutrino-images/ni-libstb-hal/commit/b73eaf403d1095583fd03b23771635f6e0d4eeb8
Denke nicht, dass die was mit der Lautstärkeregelung zu tun haben...
Eher mit der Wiedergabe generell, schätze ohne das CONTINUE startet diese erst gar nicht.
Ich bekomme im Log keine der von Dir angesprochenen Meldungen.
danke dir für info.
ich liebäugle nämlich mit einer dinobot u5 ,damit würde ich zwei fliegen mit einer klappe schlagen
da ich noch einen tuner sowie android suche / brauche. die u5 würde das abdecken u. ich hätte neutrino
bzw. ein ni-image.
dni
Beitrag von dni »
Joa, die sollte mit ni-neutrino auch funktionieren denke ich
Has thanked: 177 times
Been thanked: 48 times
Hat hier noch wer das Problem das keine EPG Info mehr bei den Quellen von
https://iptv-org.github.io/epg/guides/de/horizon.tv.epg.xml.gz
https://iptv-org.github.io/epg/guides/de/hd-plus.de.epg.xml.gz
https://iptv-org.github.io/epg/guides/ch/tv.blue.ch.epg.xml.gz
Angezeigt wird? Die Daten scheinen aber in den Quellen vorhanden zu sein.
Es wird nur die Sendung angezeigt.
hier alles soweit ok, diverse Sender wie Entertainment muss ich noch suchen, wie die Quelle heißt...
Bischen Fleißarbeit noch ...
Danke annie,
ich glaube ich habe da einen Fehler bei mir gefunden.
Ich hatte bei einiger Senderliste noch die alte URL drin (ohne .gz am Ende) und obwohl die Sender gar nicht gemeint waren, hat das wohl globale Auswirkungen auch auf Sender wo diese Endung drin war.
Komisch finde ich aber das nur die EPG Info betroffen war und nicht die Sendungen auch.
Jetzt scheint es zu funktionieren.
annie hat geschrieben: Di 13. Sep 2022, 12:54 diverse Sender wie Entertainment muss ich noch suchen, wie die Quelle heißt...
Falls Du etwas findest, sag Bescheid.
Kittybua1210!
Has thanked: 3 times
Beitrag von Kittybua1210! »
annie hat geschrieben: Di 13. Sep 2022, 12:54 hier alles soweit ok, diverse Sender wie Entertainment muss ich noch suchen, wie die Quelle heißt...
Hehe alle haben vavoo ;) Cool oder aber liebe mehr meine mega TV wegen andere Länder und ppv etc :) (120mb) ! ;)
bahner
Has thanked: 9 times
Beitrag von bahner »
hi,
Anfängerfrage,
wenn ich jetzt so eine .gz datei habe,
wo kommt diese hin?
oder muß die erst entpackt werden?
kann jemand helfen?
danke
Die EPG Datei gehört nicht auf die Box! Die wird ja ständig neu generiert. ;)
Die Datei rufst Du am besten über die Web_TV.xml Datei wo Deine IPTV Sender drin sind auf.
Beispiel für einen Sender:
<webtvs name="ORF und SRF">  <webtv title="SRF1 ²" xmltv="https://iptv-org.github.io/epg/guides/ch/tv.blue.ch.epg.xml.gz" epgmap="SRF1.ch" url="http://62.2.85.68:39981/play/a012" script="best_bitrate_m3u8.lua" description="Livestream" />
</webtvs>
bahner
also meine IPTV Sender sind in einer m3u Datei.
wo müßte ich jetzt z.B. diese datei von dir als Beispiel eintragen?
Beispiel für eine m3u Senderliste
#EXTM3U tvg-url="https://iptv-org.github.io/epg/guides/de/horizon.tv.epg.xml.gz,https://iptv-org.github.io/epg/guides/ch/tv.blue.ch.epg.xml.gz,https://iptv-org.github.io/epg/guides/de/hd-plus.de.epg.xml.gz"
#EXTINF:-1 tvg-id="SRF1.ch" tvg-name="SRF 1" group-title="DACH",SRF 1
#EXTINF:-1 tvg-id="ORF1.at" tvg-name="ORF III" group-title="DACH",ORF III
http://212.18.115.193:3549/play/a01r/index.m3u8
Du kannst mehre EPG Quellen eintragen. Die Zuordnung erfolgt dann hier über
tvg-id=""
ich suche epg u. logo für den euronews sender .. bei webtv
im normalen tv kommt bei euronews auch kein epg mehr .. unter dvb-c
https://rakuten-euronews-13-eu.rakuten.wurl.tv/manifest/playlist.m3u8
