USTVnow Webtv plugin
celeburdi
Beitrag von celeburdi »
ustvnow.lua - WebTV script for USTVnow channels
webtvsetup.lua - WebTV Host setup plugin
Install:
copy webtvsetup.lua to Plugin directory (/var/tuxbox/plugins)
copy ustvnow.lua to WebTV script directory ( /var/tuxbox/plugins/webtv)
copy ustvnow.xml to WebTV config directory (/var/tuxbox/config)
reload plugins
Set WebTV configuration (Main Menu->System settings->Multimedia->WebTV)
- add script directory to WebTV script path
- add ustvnow.xml file(s) to WebTV XML files
Setup USTVNow host:
- sign up an email login to http://www.ustvnow.com (7 HD channel ABC,NBC,CBS,FOX,CW,My9,PBS free!)
. start WebTV Setup pugin, select USTVnow host and enter login data
Use as WebTV normal channels
History
2016.11.23 v0.02 - Try to change SD to HD
2016.11.20 v0.01 - Initial release
ustvnow_webtv_lua_2016_11_23.zip
(5.76 KiB) 376-mal heruntergeladen
Zuletzt geändert von celeburdi am Mi 23. Nov 2016, 16:12, insgesamt 1-mal geändert.
Has thanked: 22 times
Re: USTVnow Webtv plugin
made an account there, put it in the .conf, but on selecting an ustv-webtv-channel:
1 key: 0160 value 1, translate: 0160 -ok-
**************************** CChannelList::zapToChannel me 0x4ea3be10 Alle Kanäle tuned 25 new NBC -> ffffffffacabb789
StopAutoRecord: autoshift 0
stopPlayBack: stopping...
stopPlayBack: stopped
CChannelList::adjustToChannelID me 0x4ea3be10 [Alle Kanäle] list size 1234 channel_id ffffffffacabb789
CNeutrinoApp::showChannelList: nNewChannel -2
CVFD::showServicename: ProSieben Maxx HD
CVFD::ShowText: [ProSieben Maxx HD]
[neutrino] StopSubtitles
CI: CAM not found
[zapit.cpp:ZapIt:508] [zapit] zap to NBC (ffffffffacabb789 tp 0)
[zapit] saving channel, apid 22a sub pid 0 mode 0 volume 75
[dvb-sub] paused
[capmt.cpp:SetMode:262] channel 25d00141270f7d69 [ProSieben Maxx HD] mode 0 STOP src 0 mask 1 -> 0 update 0 rmode 0
[capmt.cpp:SetMode:267] ##NI: (oldmask != newmask) || force_update)
[capmt.cpp:SetMode:279] ##NI: (newmask == 0)
showChannelLogo: logo_available: 0 file:
after showchannellogo, mode = 5 ret = 0 logo_ok = 0
EVT_WEBTV_ZAP_COMPLETE: ffffffffacabb789
[movieplayer.cpp:getLiveUrl:951] script: /var/tuxbox/plugins/webtv/ustvnow.lua
[Lua Script] [1;31mAchtung![0m Die Funktion [33mn:checkVersion()[0m ist veraltet,
bitte nutzen Sie [1;33mM = misc.new(); M:checkVersion()[0m.
(/var/tuxbox/plugins/webtv/ustvnow.lua:2)
[see also] [33mhttps://wiki.neutrino-hd.de/wiki/Kategorie:Lua:Neutrino-API:SonstigeFunktionen:de[0m
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 4023 0 4023 0 0 7718 0 --:--:-- --:--:-- --:--:-- 8110100 205k 0 205k 0 0 181k 0 --:--:-- 0:00:01 --:--:-- 185k
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 384 100 384 0 0 1050 0 --:--:-- --:--:-- --:--:-- 1090
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 1814 100 1814 0 0 2305 0 --:--:-- --:--:-- --:--:-- 2418100 1814 100 1814 0 0 2290 0 --:--:-- --:--:-- --:--:-- 2402
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 8412 0 8345 100 67 24749 198 --:--:-- --:--:-- --:--:-- 25916
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 205k 0 205k 0 0 227k 0 --:--:-- --:--:-- --:--:-- 231k
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 390 100 390 0 0 1012 0 --:--:-- --:--:-- --:--:-- 1051
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0100 1814 100 1814 0 0 33871 0 --:--:-- --:--:-- --:--:-- 44243
>>>>> [movieplayer.cpp:getLiveUrl:975] lua script error
CVFD::showServicename: (NBC)
CVFD::ShowText: [(NBC)]
zap failed!
CVFD::showServicename: NBC
CVFD::ShowText: [NBC]
0 key: 0160 value 0, translate: 0160 -ok-
StartSubtitles: Show
TuxTxt subtitle unpause, running 0 pid 0 page 0
which results of course in a "channel not available".
Feel free, to tell me what to do to help solving this issue...
edit: on Nevis (HD1-Platform!), Image is NI of 7.11.2016 (not the newest, I'm afraid, but that should be sufficient)
edit2: also see the error above regarding the "checkVersion" in line 2 (made it bold)
edit3: i was also a bit confused regarding the paths of where to put the different files (bcoz of nevis-platform(no persistent /var!), but thats a general Neutrino-problem imho, as you can see above, it should work in general, but, just to mention it, I did a plugin-reload, but not a reboot (coz i'm watching sth)
(puh! what a sentence ;) )
celeburdi
Is Your login correct?
Can you play channel with Browser? (Chrome)
Try it on this url:
http://m.ustvnow.com/iphone/1/live/playingnow
Celeburdi
celeburdi
new version on first post
sorry for the late answer.
yes, that is working. And therefor I assume, that my login is correct.
no, that doesn't work: "USTVnow Login Failed. Go back to try again or click below if you forgot your password." But the password is definitely correct. So, that seems to be the problem, but why? How to debug this???
@ all: does anyone got this to work, if so, on which platform (Nevis or Apollo+) ? An alle: hat das jemand ans Laufen gebracht, wenn ja, auf Nevis oder Apollo?
Has thanked: 74 times
Been thanked: 127 times
Same error as in post #2 here. Got a Zee², so it seems a general problem, not a hardware-specific one.
celeburdi
Don de Deckelwech hat geschrieben:Hi,
What type of login do you use?
This plugin works only with e-mail login.
login with email-addy and password.
Well I assume that it is working for you, so what is the difference between you and me in this case? Do you have a paid account there or a free one (only the 7 channels) like me?
Should I give you more infos, like f.e. the .cks-file from /tmp?
Bye,
celeburdi
Bye,
I have free account (only the 7 channels)
I can login on this link:
The plugin uses this link for login.
bye
.cks = cookies info
