lcd4linux:driver_lw_abp
Inhaltsverzeichnis
Logic Way ABP (ABP08, ABP09) driver
Logic Way GmbH offers the ABP08 (RS232) and ABP09 (USB) appliance control panels with a 3×16 text LCD display.
At the moment the driver supports text output, keypad usage, background color definition. The panel's clock is automatically synchronized from the PC. The panel has an built-in switch contact that can be used to scheduled power-on the computer when switched off.
Other functions (buzzer and situation-dependent background colorization) are future work.
Example
Display ABP08-16x3 {
Driver 'LW_ABP'
Port '/dev/tts/0'
Speed 19200
Size '16x3'
Background 'b 1'
# background: first character for color r, g, b, c, m, or y; number for brightness 0 = low, 1 = more
Switchcontact '/etc/wakeup.conf'
# specified file can contain a timestamp (UTC), when switch contact has to be closed for a second
# at least the file consists of a single line of text; format is:
# switchtime=1258477576
Plugins
The driver provides the following function:
| LCD::background(color) | set the background color of the panel and return it. color is a string in the same format as the Background entry: a letter for the color (r, g, b, c, m, y or w) followed by a blank and the brightness (0 or 1), e.g. 'g 1'. Without a parameter the function returns the current color. |
Example: a red background while the load is high
Widget BgTimer {
class 'Timer'
expression LCD::background(loadavg(1) > 2 ? 'r 1' : 'b 0')
active 1
update 5000
lcd4linux/driver_lw_abp.txt · Zuletzt geändert: von 127.0.0.1
