Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:widget_keypad
Keypad Widget / Keypad Driver
The keypad widget and keypad driver allows use of common buttons like up, down, left, right, ok/confirm and cancel. Added to CVS/SVN in Feb. 2006, the keypad code is still undergoing some development, and is only available on a couple of displays: Crystalfontz 635, LCD2USB and LW_ABP. LCD4Linux-0.10.1-RC1 also supports CWLinux driver. Later the keys of GLCD2USB and picoLCD Graphic and the virtual buttons of the X11 and VNC drivers were added.
To start a program by a key press without waiting for it, see the button_exec plugin; to update text widgets by a key press, see the event plugin.
It's currently the only widget which doesn't make use of the update parameter. Instead of using preset time intervals, updates are performed when the button is actually pressed or released. At that time the expression is re-evaluated. This allows you to execute some program (perhaps reboot?) or simply change the value of a variable which is used by another widget.
The mapping between keypad widgets and output lines is done in the Layout section: Just as you would place other widgets with Row*.Col* lines, you can map a keypad widget using a 'Keypad#' line. Note that the '#' used is of little consequence, just make it unique from the other keys used in that same layout.
Here's the definition of a keypad widget:
Widget <name> {
    class      'Keypad'
    position   <confirm|cancel|up|down|left|right>
    state      <pressed|released>
    expression <string>
Parameters:
positionwhat button is toggled, defaults to confirm
statewhether holding the button down or letting it go, defaults to pressed
expressionexpression to evaluate on button toggle
Example:
simple keypad example to increment a displayed variable:
Widget mytext {
    class 'Text'
    expression foo
    update 100
Widget keyok {
    class 'Keypad'
    position 'confirm'
    expression foo = foo + 1
Variable {
    foo 1
Layout demokeypad {
    Row1.Col1 'mytext'
    Keypad1 'keyok'
more sophisticated example to scroll thru dmesg output:
Widget dmesg1 {
    class 'Text'
    expression file::readline('/var/log/dmesg',currline)
    width 20
    update tick
Widget dmesg2 {
    class 'Text'
    expression file::readline('/var/log/dmesg',currline+1)
    width 20
    update tick
Widget dmesg3 {
    class 'Text'
    expression file::readline('/var/log/dmesg',currline+2)
    width 20
    update tick
Widget dmesg4 {
    class 'Text'
    expression file::readline('/var/log/dmesg',currline+3)
    width 20
    update tick
Widget keyup {
    class 'Keypad'
    position 'up'
    state 'pressed'
    expression currline = currline-1
Widget keydown {
    class 'Keypad'
    position 'down'
    state 'pressed'
    expression currline = currline+1
Layout showdmesg {
    Row1 {
        Col1 'dmesg1'
    Row2 {
        Col1 'dmesg2'
    Row3 {
        Col1 'dmesg3'
    Row4 {
        Col1 'dmesg4'
    Keypad1 'keyup'
    Keypad2 'keydown'
Variables {
    tick 100
    currline 1
an example to use with reboot confirm: (right arrow selects reboot, left arrow cancels, confirm reboots using exec)
widget keyRight{
        class 'Keypad'
        position 'right'
        state 'pressed'
        expression msg = 'Reboot? OK to confirm' ; rebootmenu = 1
widget keyConfirm{
        class 'Keypad'
        position 'confirm'
        state 'pressed'
        expression  msg = rebootmenu == 1 ? exec('/sbin/shutdown -r now',1000000) : 'Right arrow to reboot'
        exec('/sbin/shutdown -r now', 1000000);
widget keyLeft{
        class 'Keypad'
        position 'left'
        state 'pressed'
        expression msg = 'Right arrow to reboot' ; rebootmenu = 0
widget msgtxt {
        class 'Text'
        expression msg
        width 20
        update 100
Layout Default {
        Row1.Col1 'msgtxt'
	Row2.Col1 rebootmenu
        Keypad1 'keyRight'
        Keypad2 'keyConfirm'
        Keypad3 'keyLeft'
Variables {
   tick 500
   msg 'Right arrow to reboot'
   rebootmenu 0
lcd4linux/widget_keypad.txt · Zuletzt geändert: von 127.0.0.1
