Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:driver_shuttlevfd
ShuttleVFD driver
This driver supports the vacuum fluorescent display of Shuttle barebones: the Shuttle SG33G5M and the Shuttle PF27 upgrade kit. The driver was written by Matthieu Crapet.
The display has one line of 20 characters (5×8 pixels each) and a row of icons above the text. It is driven by a Princeton PT6314 VFD controller behind a Cypress CY7C63723C USB controller (vendor ID 0x051c, product ID 0x0003, or 0x0005 for the version with IR receiver).
Display Section
Display <name> {
    Driver   'ShuttleVFD'
    Port     'libusb'
Parameters
Driver'ShuttleVFD'
Portmust be 'libusb'
The size is fixed to 20×1.
Widgets
Only the Text widget and the GPO widget (for the icons) are available. The display has no user-defined characters, so there are no bars and no icon widgets.
Icons (GPOs)
The icons above the text are controlled as GPOs. A value greater than 0 switches the icon on.
GPOIcon
GPO1television
GPO2cd/dvd
GPO3music
GPO4radio
GPO5clock
GPO6pause
GPO7play
GPO8record
GPO9rewind
GPO10camera
GPO11mute
GPO12repeat
GPO13reverse
GPO14fast forward
GPO15stop
GPO16 .. GPO27volume 1 .. 12
Example
Display ShuttleVFD {
    Driver 'ShuttleVFD'
    Port   'libusb'
Widget VFD_Play {
    class 'GPO'
    expression mpd::getStateInt() == 1
    update 500
Layout VFD {
    Row1 {
        Col1 'Title'
    GPO7 'VFD_Play'
Requirements
libusb (0.1) is needed. The driver is selected at build time with –with-drivers=ShuttleVFD.
lcd4linux/driver_shuttlevfd.txt · Zuletzt geändert: von 127.0.0.1
