Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:widget_icon
Icon Widget
The icon widget is used to display user-defined characters (we call them icons). You can only use icons if your display supports user-defined characters (most displays do so) and you have reserved some characters for icons, or your display is a graphical one (e.g. T6963). For details see the documentation for your display driver.
If, for any reason, the icon cannot be displayed, an asterisk ('*') will be used instead.
The definition of an icon widget is very simple:
Widget <name> {
    class      'icon'
    speed      <number>
    visible    <expr>
    frame      <expr>
    foreground <color>
    background <color>
    bitmap {
        row1 <string>
        row2 <string>
        row8 <string>
Parameters:
speedanimation interval (msec), default: 100 msec, 0 (zero) means never (for static icons)
visibleexpression controlling the visibility (for blinking effects)
frameexpression controlling which frame to display out of an icon map (useful where 2 or more animated icons need to be synchronised)
foregroundcolor of active pixels (RRGGBBAA or RRGGBB), default is opaque black '000000ff' (see Colors for details)
backgroundcolor of inactive pixels (RRGGBBAA or RRGGBB), default is transparent 'ffffff00' (see Colors for details)
bitmap.row*string that defines the bitmap
Examples:
static icon:
Widget Lightning {
    class 'icon'
    bitmap {
        row1 '...***'
        row2 '..***.'
        row3 '.***..'
        row4 '.****.'
        row5 '..**..'
        row6 '.**...'
        row7 '**....'
        row8 '*.....'
animated icon:
Widget Heartbeat {
    class 'Icon'
    speed  800
    Bitmap {
	Row1 '.....|.....'
	Row2 '.*.*.|.*.*.'
	Row3 '*****|*.*.*'
	Row4 '*****|*...*'
	Row5 '.***.|.*.*.'
	Row6 '.***.|.*.*.'
	Row7 '..*..|..*..'
	Row8 '.....|.....'
I don't think that this need further explanation….
synchronised icons using 'frame' parameter: (see the attachment at the bottom of this page for a demo)
Widget MailIcon_left {
    class 'Icon'
    speed  100
    update 100
    # Note that the following bitmap only needs to be half of it's current size,
    #+ as it's a reversing animation, but has been extended for purpose of illustration
    Bitmap {
	Row1 '.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row2 '.....|.....|.....|.....|.....|.....|.....|....*|...**|..***|.****|*****|*****|*****|*****|*****|*****|.****|..***|...**|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row3 '.....|.....|.....|.....|.....|.....|.....|....*|...*.|..*.*|.*.*.|*.*..|*.*..|*.*..|*.*..|*.*..|*.*..|.*.*.|..*.*|...*.|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row4 '.....|.....|.....|.....|.....|.....|.....|....*|...*.|..*..|.*..*|*..*.|*..*.|*..*.|*..*.|*..*.|*..*.|.*..*|..*..|...*.|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row5 '.....|.....|.....|.....|.....|.....|.....|....*|...*.|..*..|.*...|*...*|*...*|*...*|*...*|*...*|*...*|.*...|..*..|...*.|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row6 '.....|.....|.....|.....|.....|.....|.....|....*|...*.|..*..|.*...|*....|*....|*....|*....|*....|*....|.*...|..*..|...*.|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row7 '.....|.....|.....|.....|.....|.....|.....|....*|...**|..***|.****|*****|*****|*****|*****|*****|*****|.****|..***|...**|....*|.....|.....|.....|.....|.....|.....|.....|.....|.....'
	Row8 '.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....'
    # Note that the first call to bar8 increments/decrements the counter
    #+ and that the visibility formula does not need to be so complicated for the purpose of this example.
    visible ( test::bar(8,29,0,1) > 6 & test::bar(8,29,0,0) < 21 ) * ( exec(mailcheck_script,mailcheck_refresh) > 0 )
    # Select which frame we want shown
    frame test::bar(8,29,0,0)
Widget MailIcon_right {
    class 'Icon'
    speed  100
    update 100
    # Notes in MailIcon_left apply here, too
    Bitmap {
	Row1 '.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|'
	Row2 '.....|.....|....*|...**|..***|.****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|.****|..***|...**|....*|.....|.....|.....|.....|'
	Row3 '.....|.....|....*|...*.|..*.*|.*.*.|*.*..|.*...|*....|....*|...*.|..*.*|..*.*|..*.*|..*.*|..*.*|..*.*|...*.|....*|*....|.*...|*.*..|.*.*.|..*.*|...*.|....*|.....|.....|.....|.....|'
	Row4 '.....|.....|....*|...*.|..*..|.*...|*..*.|..*..|.*...|*..*.|..*..|.*..*|.*..*|.*..*|.*..*|.*..*|.*..*|..*..|*..*.|.*...|..*..|*..*.|.*...|..*..|...*.|....*|.....|.....|.....|.....|'
	Row5 '.....|.....|....*|...*.|..*..|.*...|*...*|...**|..**.|.**..|**...|*...*|*...*|*...*|*...*|*...*|*...*|**...|.**..|..**.|...**|*...*|.*...|..*..|...*.|....*|.....|.....|.....|.....|'
	Row6 '.....|.....|....*|...*.|..*..|.*...|*....|.....|.....|.....|.....|....*|....*|....*|....*|....*|....*|.....|.....|.....|.....|*....|.*...|..*..|...*.|....*|.....|.....|.....|.....|'
	Row7 '.....|.....|....*|...**|..***|.****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|*****|.****|..***|...**|....*|.....|.....|.....|.....|'
	Row8 '.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|.....|'
    # The bar8 counter has already been incremented by MailIcon_left
    visible ( test::bar(8,29,0,0) > 1 & test::bar(8,29,0,0) < 26 ) * ( exec(mailcheck_script,mailcheck_refresh) > 0 )
Where the mailcheck_script might be something like:
#!/usr/bin/php
<?php
$mbox = imap_open("{localhost/tls/novalidate-cert}", "username", "password", OP_HALFOPEN)
      or die("can't connect: " . imap_last_error());
$status = imap_status($mbox, "{localhost}Inbox", SA_UNSEEN);
if ($status) {
  echo $status->unseen;
} else {
  echo "0";
imap_close($mbox);
Visibility
You can specify an expression for visible, which will be evaluated every time the icon is updated (every speed msec). If the expression evaluates to 0 (zero), the icon is invisible, and will be replaced by a blank. If the result is not zero, the icon will be displayed. This is useful for blinking effects, or activity display.
lcd4linux/widget_icon.txt · Zuletzt geändert: von 127.0.0.1
