Benutzer-Werkzeuge
Webseiten-Werkzeuge
lcd4linux:plugin_button_exec
button_exec plugin
This plugin starts an external program and does not wait for it. It is meant to be used with the keypad widget, to run a command once when a key is pressed.
The difference to the exec plugin: exec runs a command periodically and returns its output, button_exec runs the command exactly once per call and returns immediately.
Functions
button_exec(command, arg1, arg2, …)start command with the given arguments
  • The first parameter is the program, all following parameters are passed to it as arguments, one parameter per argument. The program is searched in the PATH; there is no shell involved, so redirections and pipes do not work.
  • The program runs in the background. The function returns '0' as soon as it has been started. There is no way to get the exit code or the output of the program.
Example
Widget StopPlayer {
    class 'Keypad'
    position 'confirm'
    state 'pressed'
    expression button_exec('/usr/bin/mpc', 'stop')
Layout Default {
    Keypad1 'StopPlayer'
Requirements
No external libraries. The plugin is selected at build time with –with-plugins=button_exec (it is part of 'all').
lcd4linux/plugin_button_exec.txt · Zuletzt geändert: von 127.0.0.1
