     ##    ##  ##      http://www.neutrino-images.de
Kernel: 2.6.34.13-nevis #1 Sat Jun 24 19:32:15 CEST 2017 @armv6l
Date: Sunday, 09 December 2018, 08:38:06
NI-FLASH-0035AE login: root
Password:
[NI-FLASH-0035AE] /var/root # dmesg
Linux version 2.6.34.13-nevis (gandharva@ghibli) (gcc version 4.9.4 (crosstool-NG crosstool-ng-1.23.0-36-g1dbb06f2) ) #1 Sat Jun 24 19:32:15 CEST 2017
Machine: CST HDx IRD
On node 0 totalpages: 98304
free_area_init_node: node 0, pgdat 804ab3e4, node_mem_map 804ec000
  Normal zone: 768 pages used for memmap
  Normal zone: 0 pages reserved
  Normal zone: 97536 pages, LIFO batch:31
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97536
Kernel command line: console=ttyRI0 mtdparts=cx2450xflash:384k(U-Boot)ro,128k(Splash),4096k(kernel),28160k(systemFS) root=mtd3 rootfstype=jffs2 rw mem=384M
Memory: 384MB = 384MB total
Memory: 384968k/384968k available, 8248k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0x98800000 - 0xe0000000   (1144 MB)
    lowmem  : 0x80000000 - 0x98000000   ( 384 MB)
    modules : 0x7e800000 - 0x80000000   (  24 MB)
      .init : 0x80048000 - 0x80063000   ( 108 kB)
      .text : 0x80063000 - 0x8048a000   (4252 kB)
      .data : 0x8048a000 - 0x804aba00   ( 135 kB)
NR_IRQS:352
console [ttyRI0] enabled
Calibrating delay loop... 593.10 BogoMIPS (lpj=2965504)
devtmpfs: initialized
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
Advanced Linux Sound Architecture Driver Version 1.0.22.1.
cfg80211: Calling CRDA to update world regulatory domain
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered tcp NFSv4.1 backchannel transport module.
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 751
io scheduler noop registered
io scheduler deadline registered (default)
io scheduler cfq registered
brd: module loaded
loop: module loaded
CX2450x MTD driver v1.0 (Jun 24 2017, 19:31:53) (c) Coolstream International Ltd.
number of CFI chips: 1
4 cmdlinepart partitions found on MTD device cx2450xflash
Creating 4 MTD partitions on "cx2450xflash":
0x000000000000-0x000000060000 : "U-Boot"
0x000000060000-0x000000080000 : "Splash"
0x000000080000-0x000000480000 : "kernel"
0x000000480000-0x000002000000 : "systemFS"
arcvmac arcvmac: ARC VMAC at 0x8048e3f8 irq 24 00:c5:5c:00:35:ae
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
cx2450x-ehci cx2450x-ehci.0: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: Product: Trident CX2450X EHCI USB-Controller
usb usb1: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
cx2450x-ehci cx2450x-ehci.1: Trident CX2450X EHCI USB-Controller
cx2450x-ehci cx2450x-ehci.1: USB 0.0 started, EHCI 1.00
usb usb2: Product: Trident CX2450X EHCI USB-Controller
usb usb2: Manufacturer: Linux 2.6.34.13-nevis ehci_hcd
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i2c /dev entries driver
ALSA device list:
  No soundcards found.
TCP cubic registered
VFS: Mounted root (jffs2 filesystem) on device 31:3.
devtmpfs: mounted
Freeing init memory: 108K
cs_frontpanel: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
Frontpanel driver v0.12.0 (Jan  6 2015, 16:58:53) (c) Coolstream International Limited
Frontpanel: wakeup source 4 time hi 0 lo 0
Frontpanel: frontpanel: Boot splash allready installed!
Memory configured as 2 banks
KAL over-allocation map ('x' = kernel, 'C' = cnxt):
-------    0 ------------- to  ------------  256 ---------------
ooooooooooooooooCCooCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
CCCCCCCxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
-------  256 ------------- to  ------------  512 ---------------
CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxoooooooooooo
. = no RAM present
C = Conexant KAL
o = unutilized or Kernel RAM
KAL: Starting the KAL...
KAL ioremap of Bank[0] uncached memory from 0x86800000 to 0x9c000000
KAL ioremap of Bank[1] uncached memory from 0x92700000 to 0xa2000000
KAL Bank[0] cached    @ V:0x81000000 == P:0x01000000, 2048 KB
KAL Bank[0] uncached  @ V:0x86800000 == P:0x06800000, 97280 KB
KAL Bank[0] content   @ V:0x81400000 == P:0x01400000, 86016 KB
KAL Bank[1] cached    @ V:0x00000000 == P:0x00000000, 0 KB
KAL Bank[1] uncached  @ V:0x92700000 == P:0x12700000, 20480 KB
KAL Bank[1] content   @ V:0x90000000 == P:0x10000000, 39936 KB
KAL: Tiled physical region 0x01400000 to 0x06680000 (15)
KAL: Tiled physical region 0x10000000 to 0x12580000 (15)
KAL: Module loaded
cnxt_base_drv: KAL Started
cnxt_base_drv: Initializing Edwards drivers...
cnxt_base_drv: Done initializing Edwards drivers.
cnxt_base_drv: Module loaded with major device 101
FB: cnxtfb_init_inst, plane OSD
FB: mode 1280x720p-50
FB: HD Mode: 1280x720 FrameRate 5
SD Mode: 720x576 FrameRate 2
/proc/cnxt_trace_flags created
 # alsa_card_CX2450_init Success  8 , 116
cs_control: module init
cs_tsx_hsdp_set_port_speed: num: 594 denom: 7
CX2450x I2C-bus driver version 0.3b (Oct  8 2013, 14:34:47) (c) Coolstream International Limited
cnxt_sata version 2.3cs
scsi0 : cnxt_sata
ata1: SATA max UDMA/133 irq 42
scsi1 : cnxt_sata
ata2: SATA max UDMA/133 irq 35
ata1: SATA link down (SStatus 0 SControl 300)
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.00: supports DRM functions and may not be fully accessable.
ata2.00: ATA-11: Samsung SSD 860 EVO 250GB, RVT01B6Q, max UDMA/133
ata2.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA/133
scsi 1:0:0:0: Direct-Access     ATA      Samsung SSD 860  RVT0 PQ: 0 ANSI: 5
sd 1:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
 sda: sda1
sd 1:0:0:0: Attached scsi generic sg0 type 0
sd 1:0:0:0: [sda] Attached SCSI disk
usbcore: registered new interface driver r871x_usb_drv
rtw driver version=v3.4.3_4369.20120622
Build at: Dec  5 2012 15:05:54
usbcore: registered new interface driver rtl8192cu
rt2870sta: module is from the staging directory, the quality is unknown, you have been warned.
rtusb init --->
usbcore: registered new interface driver rt2870
EXT4-fs (sda1): recovery complete
EXT4-fs (sda1): mounted filesystem with ordered data mode
vmac_mii_bus: probed
arcvmac arcvmac: PHY driver [Generic PHY] (mii_bus:phy_addr=0:09, irq=-1)
Slow work thread pool: Starting up
Slow work thread pool: Ready
fuse init (API version 7.13)
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
PHY: 0:09 - Link is Down
cs_frontend version 0.6b
DVB: registering new adapter (cs_frontend_dvb)
stv090x_attach: Trying to attach STV090x demodulator(1)
DVB: Unable to find symbol cx24116_attach()
DVB: registering adapter 0 frontend 0 (NXP OM3917 (TDA10025+TDA18260))...
DVB: registering adapter 0 frontend 1 (NXP OM3917 (TDA10025+TDA18260))...
PHY: 0:09 - Link is Up - 100/Full
dtv_property_dump: tvp.cmd = 0x0000002c undefined
cs_tsx_hsdp_set_port_speed: num: 66 denom: 1
